RL windscreen help - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: RL windscreen help (/showthread.php?tid=3121) |
RL windscreen help - RichardG - 21-07-2019 Evening all, does anyone have some close up shots of a steel framed RL Saloon with screen fitted in the closed position please? I can’t work out if mine is too far out at the top or too far in at the bottom, I’m thinking the top is the issue. Also a pic of the windscreen stay, mine is the earlier type but is not fitted correctly. Thank you. |
