Help identifying pressure fed nose ? - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Help identifying pressure fed nose ? (/showthread.php?tid=3120) |
Help identifying pressure fed nose ? - barryw - 21-07-2019 ![]() ![]() Hi, can anyone help me identify who may of made this pressure fed nose please? Thanks Barry RE: Help identifying pressure fed nose ? - Terrytuned - 21-07-2019 Barry it could be one of Dave Flake's Quarry engineering. Leominster now run by his son Steve. Terry. RE: Help identifying pressure fed nose ? - Scarlet O'Hara - 21-07-2019 It looks a bit like a Nippy one with the white metal bearing held in by the four bolt flange and retained from spinning by the peg at the bottom - does it have a 9E - 128 part number and 2BA cast into it? RE: Help identifying pressure fed nose ? - barryw - 21-07-2019 Hi, Thanks for your replies. Only identifying marks I can see are "BA" on the outside of the housing. Thanks Barry RE: Help identifying pressure fed nose ? - Ian Williams - 21-07-2019 I would agree that its a pressurised Nippy unit Barry. RE: Help identifying pressure fed nose ? - Scarlet O'Hara - 22-07-2019 Sorry it's a bit grubby but section drawing through sports nosecone might help you identify internals if you've got them. Photograph is of the crank starter dog which runs in the white metal / bronze bush, the bush is held in place in the nosecone by the flanged plate. ![]() RE: Help identifying pressure fed nose ? - barryw - 22-07-2019 Hi, thank you for taking the time to post the pictures and info. It explains everything. Very helpful to see a picture of the bush I am missing. Thanks Barry |
