Engine wont crank!! Austin Ruby - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Engine wont crank!! Austin Ruby (/showthread.php?tid=3116) |
Engine wont crank!! Austin Ruby - Paul t - 20-07-2019 Today was to be my 'maiden' driving experience after 3 years of refurbishment. Alas Ruby had other ideas. During my pleasurable toiling I have renewed the starter motor brushes & the resting voltage of the battery reads 6.5. Last week the engine cranked but because their was a fuel issue it failed to start. This week with fuel rectified (as far as I can determine) the engine won't crank. Battery has been recharged in the interim. Help please. RE: Engine wont crank!! Austin Ruby - Martin Paul - 20-07-2019 Check the starter motor, it could be stuck. Put the starting handle in and turn, this could release it. RE: Engine wont crank!! Austin Ruby - Steve Jones - 20-07-2019 As above, starter motor could be stuck. If that doesn't work, undo and then re-tighten all the battery connections at either end. Steve RE: Engine wont crank!! Austin Ruby - Paul t - 20-07-2019 Thank you for your replies. I can confirm that the starter motor was not stuck. The pinion was not retracting from the flywheel however so I have removed it for further investigation. The battery terminals have been removed & replaced with no improvement. RE: Engine wont crank!! Austin Ruby - charlie carpenter - 20-07-2019 Did you remove the fuel pump for the fuel problem. If so the lever could be on wrong side stopping the engine turning over RE: Engine wont crank!! Austin Ruby - AllAlloyCup - 20-07-2019 Make sure the engine and chassis are properly earthed, Regards Bill G RE: Engine wont crank!! Austin Ruby - John Mason - 20-07-2019 Paul t, Have you tried a test bulb between the starter cable (where it connects to the starter motor) and earth it should light up when the ignition is switched on. Likewise connect you test bulb between a starter motor securing bolt and a battery terminal the terminal that will complete a circuit. (I can't say which one because I don't know what polarity your car is wired.) If they both light up it shows power is getting to the starter and you have an earth. Thus you need to look at the starter. If only the test lamp comes on when connected to the starter cable you fault lies with the Earth. If it only comes on when testing the earth (starter motor retaining bolt) then you have a problem with the power supply. Should it be that power is getting to the starter but no go then have a look at the switch on the top it maybe that the contact needs cleaning. John Mason RE: Engine wont crank!! Austin Ruby - Chris KC - 20-07-2019 Will the engine turn on the handle? If so you can eliminate a few things, including a hydraulic lock due to leaky head gasket etc. RE: Engine wont crank!! Austin Ruby - squeak - 21-07-2019 If it failed to start when cranking then the pinion would not be ejected on the firing stroke and remain engaged. This of itself is not a problem, and with the starter removed you are best to follow the advice already given to prove the motor will turn manually. |
