PROPSHAFT COVER - Printable Version
+--- Thread: PROPSHAFT COVER (/showthread.php?tid=3064)
PROPSHAFT COVER - Paul Nott - 08-07-2019
Hi All
Just wondering if any one out there know's a supplier of propshaft tunnel covers for my Special. I'm now changing the seat layout from a bench to two single pads with the tunnel between the two.
Many thanks
Paul
RE: PROPSHAFT COVER - bob46320 - 09-07-2019
Peugeot 106 ??
RE: PROPSHAFT COVER - AllAlloyCup - 09-07-2019
You can easily fold one up from 18 degrees sheet steel or alloy.
You only need a bench with a decent vice and two bit of angle iron
Or find a sheet metal fabricators who will do it for you.
Bill G
RE: PROPSHAFT COVER - Jamie - 09-07-2019
Ian at Oxfordshire Sevens produces standard transmission tunnels with the handbrake cut out et al. He should be able to fabricate something bespoke as well. oxfordshiresevens.co.uk
RE: PROPSHAFT COVER - Erich - 10-07-2019
I'm assuming you mean the rear cover. Jamie Rogerson supplies replica covers. I bought one for my Ulster Rep and formed it to fit the rounded tunnel. Making the spring to hold it down was a bit more involved.
Erich in Seattle
