Lucas headlight problem - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Lucas headlight problem (/showthread.php?tid=3035) |
Lucas headlight problem - PedigreeChummy - 02-07-2019 I'm not sure if this is outside of the expertise of this forum, but can anyone tell me what I did with the two brass mounting nuts and the split washers for my headlights when I took them off at the weekend? ![]() RE: Lucas headlight problem - nrzam - 02-07-2019 You put them in a safe place! Ian RE: Lucas headlight problem - Mark McKibbin - 03-07-2019 If I lose something the best way of finding it is to start tidying up and the lost item miraculously appears, the trick to finding something is not to look for it. Good luck. RE: Lucas headlight problem - bob46320 - 03-07-2019 Search the internet, order two more and just after you fit the new ones, the old ones will turn up. RE: Lucas headlight problem - Ian Williams - 03-07-2019 At least you have put them somewhere safe and not lost them!! RE: Lucas headlight problem - "Slack Alice" Simon - 03-07-2019 I always ask my son in law, who ( I don't know how he does it) finds whatever it is, just under my nose. Seriously, though, I find that running through what I can remember of the day- usually in a quiet time about 2 in the morning - as in: "What was I wearing? What did I do next? Who was on the phone to distract me? Where did I go next? ……." Often supplies the missing items. RE: Lucas headlight problem - Chris Garner - 03-07-2019 Pray to St Anthony of Padua. RE: Lucas headlight problem - Mike Costigan - 03-07-2019 Lots of good advice here; it never ceases to amaze me how helpful this forum is ![]() RE: Lucas headlight problem - Dave Mann - 03-07-2019 Mark's method works for me every time. RE: Lucas headlight problem - David Stepney - 03-07-2019 I have a pile of old hub caps which I use as 'bits' trays. When I dismantle anything, all the displaced parts including the fasteners are put in the hub cap. Just make sure you don't upset it! My problem is tools. I put them down and then spend the next half an hour looking for that that spanner/ screwdriver that I had five minutes ago! |
