Erratic tick-over - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Erratic tick-over (/showthread.php?tid=2979) |
Erratic tick-over - Duncan Grimmond - 21-06-2019 With a Solex carb, HC head, Phoenix crank and what sounds like a "cammy" engine (I'm told by an expert) I cannot get a consistent tick-over. At cold it starts well without choke, ticks over reliably and when warm it sits merrily at around 5-700 rpm. Today was the longest drive of 8 miles at running-in speeds. On reaching the first junction where I had to stop after about 6 miles the engine died, started up easily but died again at the next few stops. As I have no crank-handle, the end of the engine having been blocked off, the dynamo (12v modified Fiat 500) is having a job to keep the new (12v) battery topped up for numerous starts. Any suggestions and ideas gratefully received. I'm also getting quite a bit of blue smoke when I set off, haven't had the plugs out yet. The engine has only run for perhaps 15 miles so far... I also think the engine might benefit from a 4-blade fan as the gap between fan and rad is a couple of inches rather than a close 1/2" as I had on my previous car. RE: Erratic tick-over - "Slack Alice" Simon - 21-06-2019 Might just be tightness in an engine being run - in. |
