window seals - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: window seals (/showthread.php?tid=2974) |
window seals - steve62008 - 19-06-2019 ordered window seals from Woolies, installed them on passenger window today (with heavy duty contact cement). Trouble is, window is nearly impossible to roll up now. Am I doing anything wrong? Same thing happened on my '58 Rolls...gotta be Arnold Swartznegger to roll 'em up. Advice appreciated, as always! RE: window seals - nrzam - 19-06-2019 This isn't based on experience of your issue but I have found "WD-40 Specialist Dry Anti Friction PTFE Lubricant 400ml" useful in a variety of situations. The manufacturer says "This solution contains PTFE which provides enhanced lubrication, leaving a dry clear film that won’t attract dirt, dust or oil. It’s quick drying and also great as a mould release agent." Ian RE: window seals - steve62008 - 20-06-2019 Thanks, I'll check it out! Steve RE: window seals - scrooge - 20-06-2019 If its the window channels , I greased those on my 34 pearl with silicone grease last year when I replaced them. They were dry and stiff but now slide free. I did rivet mine in though . |
