Cr gearbox - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Cr gearbox (/showthread.php?tid=2922) |
Cr gearbox - John L - 08-06-2019 Does anyone have a close ratio 4spd sync gearbox for sale? Preferably one that is freshly built. John RE: Cr gearbox - Ruairidh Dunford - 08-06-2019 Have you spoken to Andy Bird - he often has one rebuilt and ready to go... RE: Cr gearbox - nrzam - 08-06-2019 http://austinsevengearboxservices.co.uk I bought a rebuilt 4 speed 2 synchro with close ratios from Andy a little while ago and am very pleased with it and the service I received. Ian Singer RE: Cr gearbox - John L - 08-06-2019 Thank you very much gentlemen! I will try him RE: Cr gearbox - John L - 18-06-2019 Thank you for the advice about Andy. A gent to talk to. RE: Cr gearbox - Ian Williams - 18-06-2019 A word of warning when fitting a set of CR gears into a 4 speed gearbox. I have done a number of these over the years and in almost every case I have found the bore of the 1st motion shaft where the spigot bearing runs has required attention. It would appear that when the new gear is shrunk onto the shaft it compresses the spigot housing resulting in an internal taper and a binding bearing. I correct this with a tool post mounted grinder in my lathe, but I imagine most will not have access to one of these these so will need to farm the job out. RE: Cr gearbox - Terrytuned - 19-06-2019 I replace the Hyatt roller bearing with an inter bush from our A7 suppliers as the roller bearing can wear ridges in the gear and on the spigot, and secure the syncro cones by peening with blunt centre punch. Terry. |
