Brake cable length? - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Brake cable length? (/showthread.php?tid=2840) |
Brake cable length? - 2009jamesb - 24-05-2019 Could someone tell me the length of the rear brake cable on a 1925 Chummy. I am struggling to get the brakes adjusted and am thinking the cables were made the wrong length, the car has recently come in from America. Mine are the adjustable ones and measure 38" from end of the adjuster to the rear end without the cover. RE: Brake cable length? - Hedd_Jones - 24-05-2019 James, are you saying your cables are too short? RE: Brake cable length? - 2009jamesb - 24-05-2019 Yes by about 2" ! The cables were attached but with the cam lever sticking up and they were tight, Now I've put the levers in the correct position pointing down the cables are too short. Something is wrong! RE: Brake cable length? - JonE - 24-05-2019 is it possible the brackets/holders on the ends on the crossmember have been altered? RE: Brake cable length? - Bob Culver - 24-05-2019 Diagram fromĀ the Companion gives the length of bare cable between originalĀ fittings as 3ft 4 inches |
