Lucas Graves headlights (1931/32) - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Lucas Graves headlights (1931/32) (/showthread.php?tid=2817) |
Lucas Graves headlights (1931/32) - David.H - 20-05-2019 Can anyone confirm if the internal sidelights on these were at 6 o'clock or 12 o'clock? RE: Lucas Graves headlights (1931/32) - David Stepney - 20-05-2019 My car has them at 12.00 o'clock in which position the headlamps work fine and dip as they should. Sidelamps on. The offside headlamp is a different pattern and has the sidelamp bulb within the reflector rather than behind it under a window. RE: Lucas Graves headlights (1931/32) - Stuart Joseph - 20-05-2019 Both should be at 12.00 o'clock. bulb holders my vary though. Regards from the creative county - Staffordshire Stuart RE: Lucas Graves headlights (1931/32) - David.H - 20-05-2019 Thanks |
