Chummy length? - Printable Version
+--- Thread: Chummy length? (/showthread.php?tid=2799)
Pages: 1 2
Chummy length? - Martin Paul - 16-05-2019
Would a chummy or early box saloon fit in my garage sideways?, the garage is 103 inches wide ( 8ft 7 inches).
RE: Chummy length? - "Slack Alice" Simon - 16-05-2019
6'3" plus 2 off at half 19" (half a wheel) plus 2 off at 3.5" (tyres) = 101" plus however much the mudguards stick out.
Mudguards are removable, though.
RE: Chummy length? - Ruairidh Dunford - 16-05-2019
You will need at least 9' 8" of space for a Chummy - depending on what rear lights you have fitted.
RE: Chummy length? - Martin Paul - 16-05-2019
Thanks for replies, that idea is not going to work then.
RE: Chummy length? - JonE - 16-05-2019
So you can't have two, but you can have one lengthways and still have additional space for a jacuzzi or an engine crane.
Much easier to get it out then too, through at least one of the ends.
RE: Chummy length? - Mike Costigan - 16-05-2019
...if you park two nose-to-nose you can overlap the front wheels and they take up less space ...
RE: Chummy length? - Chris KC - 16-05-2019
How high is the ceiling?
The ceiling height is 9ft.
RE: Chummy length? - Hedd_Jones - 16-05-2019
it might fit sideways diagonally.
Ill get my coat
RE: Chummy length? - Tony Griffiths - 16-05-2019
.jpg   possible.jpg (Size: 261.46 KB / Downloads: 153)
Possible in desperation? (I'm not kidding...)
