AE Tourer and RK Saloon windscreen measurements - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: AE Tourer and RK Saloon windscreen measurements (/showthread.php?tid=2771) Pages:
1
2
AE Tourer and RK Saloon windscreen measurements - JonE - 09-05-2019 Has anyone got either that can give me a comparative measure? 1. vertical glass height at very edge of screen surround 2. overall width of the bottom of frame, from edge of surround to edge of surround. Measured on what I think is an RK screen, I have 36cm and about 89cm... but I'm interested to know whether the Tourer and Saloons are essentially the same glass, with the difference in body just being the width and material of the side members. thanks RE: AE Tourer and RK Saloon windscreen measurements - AustinWood - 09-05-2019 I think there are at least three different heights for RK saloon windscreens. RE: AE Tourer and RK Saloon windscreen measurements - JonE - 09-05-2019 good! even better... Can you provide me with one?! I'd like to find out what they are, and if the difference is the glass or the surround, Jim. RE: AE Tourer and RK Saloon windscreen measurements - Hedd_Jones - 09-05-2019 If you can wait till tommorrow evening ill measure my AE for you. But please, centimetres are only used by dressmakers! RE: AE Tourer and RK Saloon windscreen measurements - JonE - 09-05-2019 any way, miles, km... whatever... no hurry. Have one in from a single-screened Tourer abroad. 26cm/86cm (they provided the units, Hedd!) I'm assuming this might be an earlier, narrower body than either AE or RK. RE: AE Tourer and RK Saloon windscreen measurements - AustinWood - 10-05-2019 I shall be over at the garage later today and can measure the screen. The wooden cross-piece below the screen differs in height with the different screens. I think the overall height doesn't change. RE: AE Tourer and RK Saloon windscreen measurements - AustinWood - 10-05-2019 My RK screen is 35" wide, 15" high at the centre and 16-3/4" high at the edges. Dimensions taken including the frame. RE: AE Tourer and RK Saloon windscreen measurements - JonE - 11-05-2019 THanks Jim. Yes, perhaps you are right - need the height of the wooden under piece generally to make any sense. Half inch difference in your frame height from Ken's similar Fabric car with same width measurement... but no idea presently on whether that affects the roof height! RE: AE Tourer and RK Saloon windscreen measurements - Howard Wright - 11-05-2019 Hi Jon This any help? (Taken from my RK) Howard RE: AE Tourer and RK Saloon windscreen measurements - Ian Williams - 11-05-2019 I can come up with a slightly different set to Jim but perhaps it is just the way we are measuring that differs Jon, Show a picture with the dimensions you want and you might get some sense out of your question. It would help if we all used HM imperial measurements then less confusion for all. |
