STEERING COLUMN SPLINE. - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: STEERING COLUMN SPLINE. (/showthread.php?tid=2576) |
STEERING COLUMN SPLINE. - Rpm - 28-03-2019 Hi Guys . My steering column spline has been extended,the longer spline welded to original spline. My question is ,if I cut off the extended part , do you think iI will be able to recover the original . Some of the original spline is showing. Any thoughts or views appreciated. Regards Rob RPM RE: STEERING COLUMN SPLINE. - Zetomagneto - 29-03-2019 Possibly, but presumably the weld has destroyed the threads.Would need to see a photo really. Sounds like a lathe job, part off the extension leaving enough to screwcut a new thread. RE: STEERING COLUMN SPLINE. - Chris KC - 29-03-2019 Suggest you post a photo Rob. I can't really see why not as long as you are able to clean up the spline ends. Less sure about the metallurgy - whether it may have been weakened. RE: STEERING COLUMN SPLINE. - dickie65 - 29-03-2019 Hi Rob, What car is the column from ? Nippys had a longer column so it could be an extended box saloon column made to fit a Nippy. Cheers Richard RE: STEERING COLUMN SPLINE. - JonE - 29-03-2019 what about the steering box, Rob - is that a 9E one or is it a standard one wedged to the right sport angle? RE: STEERING COLUMN SPLINE. - Rpm - 31-03-2019 Hi Guys apologies for late reply, The box has 9E ... stamped on the main body. Don't think colunm been messed with , just that the wheel, Bluemels stands away from colunm by about 2" and what looks like a spine on top of spline and blob of weld. Could be the original was damaged , although you would have thought if that the case, you would cut old off and reweld or have re cut. I will post a pic tomorrow. Thanks again all. Rob RPM |
