Front shock absorber friction disc sizes - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Front shock absorber friction disc sizes (/showthread.php?tid=2493) |
Front shock absorber friction disc sizes - agmatthews - 09-03-2019 Hi All, I'm at the point of assembling the front shock absorber on my '29 SWB chassis and have reached one of those "ummm?" moments. The front shock absorber chassis mount has a 2 inch 'boss' on one side while the the friction discs I have all have a 1 1/2 inch hole in them. The discs fit the shock absorber arms perfectly but not the chassis mount. The cherished suppliers only seem to supply discs with one size hole - 1 1/2 inches. Couple of questions:
Andrew Melbourne, Australia ![]() RE: Front shock absorber friction disc sizes - Ruairidh Dunford - 09-03-2019 Big 7s have different sized parts here, from memory... RE: Front shock absorber friction disc sizes - Paul N-M - 09-03-2019 Looks Big Seven to me. Paul N-M RE: Front shock absorber friction disc sizes - agmatthews - 09-03-2019 ‘tis but a wee chummy, maybe one that had ideas of growing up one day! Anyone think it’s a bad idea to open up the hole in the friction disc to get it to fit? RE: Front shock absorber friction disc sizes - Ruairidh Dunford - 09-03-2019 May be easier to get a Seven one, they are readily available. RE: Front shock absorber friction disc sizes - Robert Foreman - 10-03-2019 You could also bolt it back onto a fixture in a lathe and turn it down to the required diameter RE: Front shock absorber friction disc sizes - Derek Sheldon - 10-03-2019 Ascertain the make up of the friction disc before you consider making the hole larger, some of these items have nasty stuff in them. |
