Zenith VA26 carburettor problems - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Zenith VA26 carburettor problems (/showthread.php?tid=2472) |
Zenith VA26 carburettor problems - John Mason - 01-03-2019 Hi all, I have just now put a new choke spring on the carburettor of my Mk1 Ruby (Zeneth VA26). The choke now works well but I have a problem with the carb. When the engine has warmed up there is a big flat spot from tick over to the engine reving up so much that it cuts out unless the throttle is feathered quite a lot. I have checked the tappets, timing and points and all are correct as I believe they have to be before adjustment to the carb. My question is what do I adjust. One further point to to eliminate all possibilities I have fresh petrol in the tank. John Mason. RE: Zenith VA26 carburettor problems - Ian McGowan - 04-03-2019 Hi John, working on the basis that it, presumably, ran OK before you had the carb off to fit the new choke spring, I suggest that you possibly have an air leak at the carb/ manifold joint. Working on the principle of "what Have I done that could possibly bugger it up" ??? RE: Zenith VA26 carburettor problems - Reckless Rat - 04-03-2019 Either that or one of the jets in the bottom of the float chamber is blocked. RE: Zenith VA26 carburettor problems - Steve Jones - 04-03-2019 Again, typical of an inlet side air leak. Before looking at the more obscure things, always check the simple things first. Steve RE: Zenith VA26 carburettor problems - John Mason - 04-03-2019 Thank you all will check for air leaks and blocked jets (wish I had an air line). I do however have a can of pressurised carburettor cleaner with a plastic tube extension. John Mason RE: Zenith VA26 carburettor problems - Reckless Rat - 04-03-2019 The two jets in the bottom of the float chamber are removeable - one of the screws holding it on to the carb body should have a squared end - use that to unscrew the jets. RE: Zenith VA26 carburettor problems - Pricey - 05-03-2019 John I had a similar issue which I posted about here http://www.austinsevenfriends.co.uk/forum/showthread.php?tid=1458&page=3 My issue was the emulsion block which when lapped into the carb body cured the issue. See this article http://www.da7c.co.uk/technical_torque_articles/zenith_26_va_carburettor.html HTH Cheers Dave |
