NIPPY SCREEN TOGGLES - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: NIPPY SCREEN TOGGLES (/showthread.php?tid=2470) |
NIPPY SCREEN TOGGLES - Rpm - 01-03-2019 Hi all ,may I ask someone to post a picture of the Nippy Rattle toggles on the windscreen corners. Im assuming these are not available as a reproduction items. I also want to make Nippy doors locks, unless someone can help with these items. Can hear you lauging already. ![]() ![]() Thanks all. Regards Rob RE: NIPPY SCREEN TOGGLES - Chris KC - 01-03-2019 Rob, You need to talk with Chris Gould - he actually wrote a guide to reproducing Nippy door catches. https://aus7in.wordpress.com/2016/08/22/door-locks/ RE: NIPPY SCREEN TOGGLES - daveg - 01-03-2019 I am not sure which bits are the "rattle toggles" but there are some pictures here of Nippy windscreens that might help. https://aus7in.wordpress.com/2016/06/08/nippy65-windscreen-frame-variations/ RE: NIPPY SCREEN TOGGLES - daveg - 01-03-2019 Thinking more about it I wonder if this is what you need, I have always referred to it as an acorn ![]() If so I bought some from Willie Mckenzie, Austin Repro. http://austinrepro.com/ RE: NIPPY SCREEN TOGGLES - Rpm - 01-03-2019 Thanks, Chris, Dave. will see if I can gain more info on door catches, C.guold. Re the windscreen, its the turn catches each end of the screen, which I assume stops screen rattle and also stops it opening .The catches are mounted on the outside bottom each end. Regards Rob RE: NIPPY SCREEN TOGGLES - daveg - 01-03-2019 I think I now know what you need ![]() ![]() Willie also supplied me with these and the stepped screw to attach them. RE: NIPPY SCREEN TOGGLES - EB65 VN - 01-03-2019 Exactly as I was able to obtain, from the same excellent source! ![]() RE: NIPPY SCREEN TOGGLES - Rpm - 01-03-2019 Thanks Guys , does Chris Gould supply these toggles? great to see a close-up. least i now know what they look like. Regards Rob |
