Zenith 26VA choke flap spring - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Zenith 26VA choke flap spring (/showthread.php?tid=2457) |
Zenith 26VA choke flap spring - John Mason - 28-02-2019 Hi all, can anyone tell me what the heavier of the two choke springs fixes to to give it tension when you pull the choke out. I have an exploded drawing of the carb and can see how the spring fits to the choke flap assembly but cannot work out what the end goes to. John Mason RE: Zenith 26VA choke flap spring - Colin Morgan - 28-02-2019 I think the end of the spring that faces forward just lies trapped inside, and resting on, the bottom of metal 'cup' air filter. Colin |
