Sluggish starter - Printable Version
+--- Thread: Sluggish starter (/showthread.php?tid=2451)
Sluggish starter - P J Quinn - 26-02-2019
Hi
My A7 was turning over very sluggishly on the starter before eventually firing up. As the battery was cracked at the pillar, I bought a new one and fully charged it only to find the same problem persisted. The second problem is the car is not charging either. What could the problems be and could they be connected?
P J
RE: Sluggish starter - Ruairidh Dunford - 26-02-2019
Try running a good strong separate earth to the body of the starter motor - mounting bolts are good - and try again.
If you have no luck with that, try new brushes, if they are available.
RE: Sluggish starter - P J Quinn - 27-02-2019
Thanks Ruairidh. I'll try that.
PJ
RE: Sluggish starter - John Mason - 27-02-2019
You could also try checking the battery to earth lead as sometimes where it connects to the body it gets rusted or corroded. That can take a lot of the power that goes to the starter.
John Mason
Thanks John
The engine was refurbed earlier this year and earth connection is good. In reply to Ruairidh the brushes on the dynamo are also good and dynamo has been tested and is also working.
P J
RE: Sluggish starter - Ruairidh Dunford - 27-02-2019
Did you try the separate earth, a good strong jump lead would do temporarily?
No Ruairidh I didn't get a chance yet but will do when I'm off on Saturday.
P J
