Something new. - Printable Version
+--- Thread: Something new. (/showthread.php?tid=2443)
Something new. - Alan - 24-02-2019
Taking apart a magneto engine, today, I found this modification to the cam centre bearing. It’s surely not original. Now I can’t decide whether to revert to rollers or leave it as it is.
RE: Something new. - Ruairidh Dunford - 24-02-2019
I have dismantled at least two engines where the centre rollers, ring and casting were completely missing, they still ran!
RE: Something new. - Dave Wortley - 24-02-2019
Isn't that a mod that Jim White showed in The Special Builder's Guide?
RE: Something new. - Alan - 24-02-2019
Yes it is. I hadn’t seen one before though
RE: Something new. - Chris KC - 24-02-2019
I think something similar is described in the 750 Companion, isn't it?
If it's doing its job properly I don't see any reason to replace it.
RE: Something new. - Tom the Blacksmith - 24-02-2019
Hi Alan.
I've made something very similar so I'd keep it! The problem I had was that the cam roller track was worn so replacing outer and rollers wasn't going solve the problem. That and I hate crowded rollers anyway.
