Brake Lights staying On - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Brake Lights staying On (/showthread.php?tid=2414) |
Brake Lights staying On - Mixer - 16-02-2019 Hi all, My MkII Ruby brake lights remain on when foot is removed from the pedal, I have to pull it back to extinguish, much of a job to adjust?? ![]() RE: Electronic ignition - John Mason - 17-02-2019 Mixer, does the pedal move freely on the pivot point. It appears from what you are saying that the pedal does not come fully back of its own accord. Try a little lubrication and move the pedal up and down to get the oil in. John Mason RE: [split] Brake Light Switch Adjustment - Timothy P - 17-02-2019 Hi Mixer, Hope you don't mind, I've moved your post to it's own thread. hopefully you'll get some more responses here. RE: Brake Lights staying On - Peter Naulls - 17-02-2019 Mine does exactly the same. It seems that the weight of the pedal is sufficient to keep in there. It had never occurred to me that there was anything wrong with it. Peter. RE: Brake Lights staying On - Derek Sheldon - 18-02-2019 Might be worth taking the two screws out of the switch and check the return spring at the connections . Might be worth taking the two screws out of the switch and check the return spring at the connections . RE: Brake Lights staying On - Reckless Rat - 18-02-2019 The switch plunger is normally connected to the footbrake actuating rod by a coil spring and a small bracket attached to the rod. It may just be a simple case of relocating the end clamp to allow the plunger to fully enter the switch when in the 'rest' position. In other words reducing the spring tension a little. RE: Brake Lights staying On - Derek Sheldon - 18-02-2019 U |
