Thread Identification Please? - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Thread Identification Please? (/showthread.php?tid=2370) |
Thread Identification Please? - PhilM - 08-02-2019 Having just completed the overhaul of my 4 speed (3 synchro) gearbox I find that the thread on the end of the 3rd motion shaft for the drive shaft flange is damaged, the nut is also damaged but I think the shaft thread will clean up with the correct die. Can somebody please tell me what this thread is so that I can obtain the correct die, it looks to be 5/8" x 16 tpi which suggests it could be whitform but I would welcome confirmation of this. I'll also be looking for a replacement nut but I haven't found one listed on any of the usual suppliers parts lists, could anybody point me in the right direction?? Many thanks, ..... Phil. RE: Thread Identification Please? - Parazine - 09-02-2019 5/8 x 16 tpi, Sir Herbert's little ba***rd thread. Same as the crankshaft and half shaft. Someone suggested that it was some redundant tooling Austin bought up, someone else claimed a connection with railways I seem to remember. Tooling available from Tracy Tools in Devon. Sorry, just to make it clear, I measured it and it is 5/8 x 16 tpi! RE: Thread Identification Please? - Chris KC - 09-02-2019 Hello Phil, I just ducked out to the lock-up to check, forgive me if I mis-type as my fingers are now frozen! Yes, it 5/8" x 16 tpi. David Cochrane lists 5/8 x 16tpi taps and dies, I think it may be the same thread as a half-shaft nut. A die is one option, or a thread chaser is sometimes handy for tidying up minor damage on larger threads. I'm afraid I don't have a spare nut to hand or I'd post it to you. But if you get stuck p.m. me, I might have a rusty old one in my used nuts and bolts bucket. p.s. If I'd known Parazine was looking too I'd have stayed in the warm! But yes I also measured it. RE: Thread Identification Please? - PhilM - 09-02-2019 Many thanks to you both for braving the elements in order to confirm the thread size, I hope the frostbite doesn't have any lasting consequences. I'll probably give David Cochrane a ring to make sure the dies he has are correct for the job and if all else fails I could buy the tap as well and make a new nut, quite an expensive exercise though for something I may only do once. Regards to both, .... Phil. RE: Thread Identification Please? - David Cochrane - 09-02-2019 Phil - give me a call next week and leave a message - I will ring you back. I'm out quite a bit next week so apologies in advance if it takes me a day or so before I do. RE: Thread Identification Please? - PhilM - 10-02-2019 (09-02-2019, 10:42 PM)David Cochrane Wrote: Phil - give me a call next week and leave a message - I will ring you back. I'm out quite a bit next week so apologies in advance if it takes me a day or so before I do. Many thanks David I'll give you a call as suggested. ..... Phil. |
