Repairing Lucas ignition and charging switch - Printable Version
+--- Thread: Repairing Lucas ignition and charging switch (/showthread.php?tid=2311)
Repairing Lucas ignition and charging switch - Ian M - 30-01-2019
About 25 years ago, the ignition switch on my Mk1 Ruby developed a fault, whereby it tended to stay permanently on whenever the spade key was turned to the 'off' position. I imagine this is now a fairly common fault, given the age of the component involved. As a short term workaround, I simply installed a separate switch and re-routed the wiring accordingly.
Fast forward to now and I'm wondering if there is anyone out there who can actually repair these things? I've so far resisted the temptation to take it apart myself, on the grounds that I've heard these are tricky to get back together again. Many thanks.
In the event that I end up tackling this job myself, the article below from the Cornwall Austin Seven Club could be just the thing!
http://www.austin7.org/Technical%20Articles/PLC%20Switch%202/
RE: Repairing Lucas ignition and charging switch - Reckless Rat - 30-01-2019
Rather than experiencing the mechanical explosion when taking one apart, I by-passed it using a separate switch mounted under the dashboard.
