Remote gear change - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Remote gear change (/showthread.php?tid=2293) Pages:
1
2
Remote gear change - Mark McKibbin - 27-01-2019 Does anyone know where I could purchase a remote gear change for a 4 speed gearbox, many people list them but they are always out of stock. RE: Remote gear change - Tony Betts - 27-01-2019 I have one ELTOS 4 speed remote on the shelf. Price £475.00 The castings are in for the next batch, sould be ready around March. tony.7ca@aol.co.uk Due to picking up frogeye sprites Thursday and Friday??? The phone will be off monday. Thanks Tony. RE: Remote gear change - wooster - 02-02-2020 I'm also looking for a remote gear change for a 4-speed box. Have you got one in stock? Cheers Rich RE: Remote gear change - Zetomagneto - 02-02-2020 Rich, that’s what Tony’s saying, he has one in stock RE: Remote gear change - Tony Press - 03-02-2020 On your marks ! RE: Remote gear change - Charles Levien - 03-02-2020 You could look at the Cambridge Engineering solution which uses a four speed gearbox top mounted on the transmission tunnel at the remote location, near your hip. That gives you forward gears without problem. Reverse is achieved by a small bridge halfway between remote and gearbox — by pushing the remote gear lever down you get a lift at the gearbox. RE: Remote gear change - Robert Leigh - 03-02-2020 I made my own version of this, and it works very satisfactorily, and mine is only fixed to the gearbox eliminating any lost motion by movement of the lever ball in relation to the gearbox as the engine moves on the chassis. I'll try to post a picture later but I am not good at this. Robert Leigh RE: Remote gear change - Barry - 03-02-2020 It's a well-known fact that Robert's car only has one gear: forward and fast! RE: Remote gear change - Robert Leigh - 03-02-2020 Robert Leigh RE: Remote gear change - Tony Press - 04-02-2020 Or you can use David Lowe's basic 4 speed gearbox remote- http://www.austin7club.org/How%20To%2012.htm Tony. |
