RK window thumbscrew - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: RK window thumbscrew (/showthread.php?tid=2277) |
RK window thumbscrew - Howard Wright - 23-01-2019 Hi All Could any kind person let me know what the shape and size of the thumbscrew that holds open the front window on the RK is? I currently use a modern flat version (see below) but I'm not sure this is correct and think it should be a round knurled knob. I know it is 1/4 whit but what size is the round knurled section? Howard RE: RK window thumbscrew - Ian Dunford - 23-01-2019 Mine is the same as an Opal/2/4 seater but it’s 600 miles away at the moment so I can’t photograph it just now. However knurled and round they are.Sorry. RE: RK window thumbscrew - Parazine - 23-01-2019 Here you go ![]() RE: RK window thumbscrew - Parazine - 23-01-2019 Forgot to mention, the thumbscrew is 7/8" diameter. RE: RK window thumbscrew - Nick Lettington - 23-01-2019 (23-01-2019, 11:11 AM)Ian Dunford Wrote: Mine is the same as an Opal/2/4 seater but it’s 600 miles away at the moment so I can’t photograph it just now. However knurled and round they are.Sorry. But without the shoulder on my 4 seat ORT RE: RK window thumbscrew - Howard Wright - 23-01-2019 Thanks all Super info. Both look as though they are (or have been) nickel plated? I'll probably have a go at turning some stainless rather than go to the trouble of plating Thanks again Howard RE: RK window thumbscrew - Peter Johnson - 23-01-2019 I think that I have a pair of original that I purchased on eBay with some other windscreen parts of you are interested. I’ll have a look in the garage. On my saloon, the originals are steel and so the plate had rusted off, but were originally nickel plated (1929 RK Saloon) Peter |
