Chassis numbers - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Chassis numbers (/showthread.php?tid=2177) |
Chassis numbers - David.H - 01-01-2019 While scraping away to find the Chassis number on the AD Chummy prior to sending papers off top the DVLA I find there are several ! One matches the scuttle plate, but the other is curious. Any ideas? RE: Chassis numbers - Zetomagneto - 01-01-2019 (01-01-2019, 02:59 PM)David.H Wrote: While scraping away to find the Chassis number on the AD Chummy prior to sending papers off top the DVLA I find there are several ! One matches the scuttle plate, but the other is curious. The other number is the original engine number RE: Chassis numbers - Tony Betts - 01-01-2019 Hi David, As suggested above, they are the original engine and chassis numbers. I thought at first they both had a C in front. But I think if you clean them a bit more the top number will have C for chassis. And the bottom number will have E for engine in front. All correct for a change. Tony. RE: Chassis numbers - David.H - 01-01-2019 Thanks Tony & Zetomagneto...sadly the engine is a bit later ...M79342, and a coil conversion! Anyone got 53532...... D |
