Wiring for Lucas -Graves lamps - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Wiring for Lucas -Graves lamps (/showthread.php?tid=2175) |
Wiring for Lucas -Graves lamps - David.H - 01-01-2019 I am now at the stage of replacing the wiring on the 1932 AG tourer and am wondering about the headlamp wiring. The car has it's original Lucas -Graves dipping headlamps with a dip switch on the column. My query is that the holes for three wires into this original switch are tiny and don't look "big " enough to take the load for headlamps; they go on down the column & on to a 4 way junction box on the scuttle behind the tank. I have taken advice from this forum (I hope I can find it!) about how to wire the lamps up, but wonder if I should try & put a relay (are there 6v relays? I have lots of 12v ones) to take the load off this switch ...or even an in-line fuse in the system Found & (this time) printed the diagram! How could/should I put a relay in...? RE: Wiring for Lucas -Graves lamps - Stuart Joseph - 01-01-2019 Hello David, I would always advise the fitting of a relay which can be located under the dash. 6v relays are available and are stocked by David C of our cherished suppliers or on line. Regards from the creative county - Staffordshire Stuart RE: Wiring for Lucas -Graves lamps - David.H - 01-01-2019 Thanks...now to sort out where the relay wires go. I am sure someone will tell me where to put them!! RE: Wiring for Lucas -Graves lamps - Stuart Joseph - 01-01-2019 David, if you would send me an email - stuart.joseph@btinternet.com - with your postal address I will send you (via snail mail) a wiring diagram. Regards Stuart |
