Grasshopper Replica - Printable Version
+--- Thread: Grasshopper Replica (/showthread.php?tid=216)
Pages: 1 2 3 4
Grasshopper Replica - Special Bits - 10-09-2017
Over the years on the old thread I often asked questions about Grasshoppers, even when they became politically incorrect! The driving force behind this was to build a replica.
Well, I can now share a couple of pictures of the car, which will hopefully be sufficiently finished to do the PWA7C winter trial in December. My Father has built the body, with my assistance when I have been able, many hundreds of hours have gone into it so far. Dimensionally it is quite an accurate copy of BOA 59. The rad cowl is a temporary GRP one, to be replaced with one made in brass and plated, in due course.
Mechanically it is fairly standard Austin Seven, with a mildly breathed upon engine, for the time being. The intention is to build a blown engine in time (anyone know the whereabouts of a Centric 125?) The colour is an attempt to match the paint found on an original component in an undisturbed state, its not quite right, but not that far off.
Thanks for all the help received so far from forum members and the wider A7 community.
Stuart Palmer
RE: Grasshopper Replica - Ruairidh Dunford - 10-09-2017
Nice one Stuart!
RE: Grasshopper Replica - Timothy P - 10-09-2017
Brilliant Stuart, looking really good.
Look forward to seeing it out on the hills.
RE: Grasshopper Replica - Dave Wortley - 10-09-2017
That's really good Stuart! Lots of great craftmanship there.
Cheers,
Dave.
RE: Grasshopper Replica - Mark Atkinson - 10-09-2017
Hello Stuart,
                 The car looks very well, all credit to both of you. Please do keep on posting pictures of the build and updates on your progress.
Do you have any hints or tips for fellow replica builders? Spending so many hours locked away in my garage building my own car, I am always hungry for threads about similar builds and how my fellow builders go about the task.
Regards, Mark.
RE: Grasshopper Replica - Bill Sheehan - 12-09-2017
Great work Stuart - I'm Green with envy. Cheers, Bill
RE: Grasshopper Replica - Special Bits - 15-09-2017
I have been away all week earning play tokens. Thanks for all the kind words.
Mark, the only advise I can offer, is keep at it, its very easy to allow life to take priority over the important things! lol
Stuart
RE: Grasshopper Replica - Special Bits - 04-11-2017
Unfortunately the pursuit of food tokens has kept me away from the Grasshopper project over the last couple of months, however Father has been continuing the work between other tasks. The back end is coming on now.
RE: Grasshopper Replica - Tony Press - 05-11-2017
(04-11-2017, 09:08 PM)Special Bits Wrote:  Unfortunately the pursuit of food tokens has kept me away from the Grasshopper project over the last couple of months, however Father has been continuing the work between other tasks. The back end is coming on now.
[Image: photo.php?fbid=1711488345589355&set=gm.1...ater&ifg=1][Image: photo.php?fbid=1711488345589355&set=gm.1...ater&ifg=1]
Back end is looking good although the wheels look a bit close to the body
Unfortunately I only get one photograph - the other two are just text ? (same in the first post )
Cheers, Tony.
RE: Grasshopper Replica - Derek Sheldon - 05-11-2017
Over the years I have seen comments like “ the unmentionable “ “ politically incorrect “ “ those green things”. Would somebody explain exactly why the GRASSHOPPER is so devilled.
