Windscreen closer - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Windscreen closer (/showthread.php?tid=2096) |
Windscreen closer - Dave Mann - 09-12-2018 Can anyone identify this windscreen closer? The dashboard end mounting is different to the usual RN/RP mounting. RE: Windscreen closer - Dave Mann - 10-12-2018 I thought someone could identify this, so it can go to a home, if not it'll become an RN one. RE: Windscreen closer - Jeff Taylor - 10-12-2018 I wished it had been an RP one Dave as I'm in need of one for my 1934 van rebuild. As far as I'm aware RN and RP have different shaped dashboard mounts, in all other respects I believe they're the same. Jeff. RE: Windscreen closer - Hedd_Jones - 10-12-2018 Its probably Austin 10 Dave. Jeff. The RP/RN ones differ in the mount to the screen RE: Windscreen closer - Jeff Taylor - 10-12-2018 (10-12-2018, 04:02 PM)Hedd_Jones Wrote: Its probably Austin 10 Dave. Thanks Hedd, the screen I have is definitely an RP chrome on brass - so if the mount to the screen is different, what about the mount to the dashboard, I thought that too was a slightly different shape between the RN / RP given the dash panel is a slightly different shaped pressing ? RE: Windscreen closer - Dave Mann - 10-12-2018 Thanks Hedd, now I'll see if I can find it a home. Yes the windscreen ends of the RN & RP are different however, some RNs have acquired RP windscreens so beware whilst the dash ends are the same. |
