NGK spark plugs - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: NGK spark plugs (/showthread.php?tid=209) |
NGK spark plugs - richard tatton - 07-09-2017 The spark plugs I changed today were NGK6. I was about to replace with some labelled NGK7 but wasn't sure if they were ok as the number was different. I played safe and replaced with a new set of NGK6 but just wondered if I can use the NGK7 in a 1934 box saloon or would they be wrong. I'm not sure where they came from but I've been carrying them around under the back seat for years! Thanks Richard RE: NGK spark plugs - Peter Clayton - 07-09-2017 The 7 is a cooler running plug so may oil up, however would be a good spare. This site gives some interesting info http://www.briskusa.com/spark_plug_cross_reference_heat_range_chart |
