Brake rod - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Brake rod (/showthread.php?tid=2042) |
Brake rod - AustinA - 25-11-2018 Hi all, can anyone recommend what grade steel I need to use to make a new brake rod? The rod from the pedal to the cross shaft RE: Brake rod - Ruairidh Dunford - 25-11-2018 New ones here: https://www.theaustinsevenworkshop.com/products/br0257-brake-pedal-rod-spring-nut |
