help how do you reaassemble a rear window and rubber for a 1936 austin ruby - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: help how do you reaassemble a rear window and rubber for a 1936 austin ruby (/showthread.php?tid=202) |
help how do you reaassemble a rear window and rubber for a 1936 austin ruby - syd nally - 06-09-2017 the rear window fell out of our Austin 7 ruby and we nead help to fit it thanks syd RE: help how do you reaassemble a rear window and rubber for a 1936 austin ruby - Nigel was in Brittany - 06-09-2017 What I did with mine was put the glass into the rubber and fitted the glass from inside the car with a coating of black Stixall ,then with a bit of 2x1 screwed across the glass to retain it until the Stixall cured. When I had held it in tight with the 2x1 I used a garage wet wipe to remove any residue from the exterior paint work. Todays top tip : if you are siliconeing around a basin etc , use a wet wipe to go over the silicone rather than your wetted finger, it leaves a lovely finish. RE: help how do you reaassemble a rear window and rubber for a 1936 austin ruby - john williams - 06-09-2017 (06-09-2017, 04:08 AM)syd nally Wrote: the rear window fell out of our Austin 7 ruby and we nead help to fit it Have a look at www.southwalesaustinsevenclub.co,uk. They have an article on fitting rear windows. Usually a two man job. John RE: help how do you reaassemble a rear window and rubber for a 1936 austin ruby - Nick Salmon - 07-09-2017 (06-09-2017, 11:22 PM)john williams Wrote:(06-09-2017, 04:08 AM)syd nally Wrote: the rear window fell out of our Austin 7 ruby and we nead help to fit it The full link to the article is: http://southwalesaustinsevenclub.com/wp-content/uploads/2015/10/SEAL-4.png RE: help how do you reaassemble a rear window and rubber for a 1936 austin ruby - Mark-and-Kim - 11-04-2020 This confirms my findings and is exactly why I am about to do. At least now I know its the correct thing to do. Thank you. |
