LED Headlights - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: LED Headlights (/showthread.php?tid=2019) |
LED Headlights - bob46320 - 15-11-2018 I follow the legal use of LED headlights on UK roads etc, but I am searching for LED replacement bulbs for P15d 30 6 volt types. I found some from DynamoConversions, but Ouch, they are expensive. Anyone else found a source for them or a way of converting the P15 30 format to a more common bulb socket. 12V-25-25W-RP35-Motorcycle-Lamp-Bulb.jpg_300x300.jpg (Size: 16.1 KB / Downloads: 265) RE: LED Headlights - Duncan Grimmond - 16-11-2018 I bought Classic Dynamo conversions led replacements and though the are a bit more pricey than incandescents or halogens they seem to be longer living. I've had 4 years hard regular use without replacement. The best thing is that you can see further and clearer in the dark IMHO. |
