Ulster Rep front shock - Printable Version
+--- Thread: Ulster Rep front shock (/showthread.php?tid=1970)
Ulster Rep front shock - Erich - 04-11-2018
I'm about ready to refit the rebuilt front shock to my SWB Ulster Rep. When it came to me, the shock was attached to the axle with the rubber bushed aluminum links mounted so that the the shock ends attached with the alloy links pointing downward from the axle. I am attaching a photo of how it was mounted. I have looked in photos to see the the alloy links pointing upward from the dropped axle. Which is correct?
Erich in Seattle
RE: Ulster Rep front shock - Terrytuned - 04-11-2018
Erich the shock arms need to be horizontal to be most effective, so it depends on the position of the central mounting point.
Terry.
RE: Ulster Rep front shock - Alan - 04-11-2018
If it helps mine go downwards as the photograph. Don’t take that as historically correct, but it is as Terry says, the right way from a functional point of view.
RE: Ulster Rep front shock - Chris KC - 04-11-2018
I was going to say '+1' but it seems my message is too short!
RE: Ulster Rep front shock - Erich - 04-11-2018
Thank you all. Do genuine Ulsters have a shorter central mount? I have seen some older photographs of Ulsters which appear to have the links going upward. Nippys and my 75 go downward.
Erich in Seattle
