Size of socket for half shaft nuts? - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Size of socket for half shaft nuts? (/showthread.php?tid=1954) Pages:
1
2
Size of socket for half shaft nuts? - Joe eck - 01-11-2018 I have a1937 Ruby and I am conscious that I should be checking the tightness of the half shaft nuts. I do not have a socket big enough so will have to purchase one !!! Could anybody let me know what size socket will be required ? Thanks Joe. RE: Size of socket for half shaft nuts? - bob46320 - 01-11-2018 Mine is marked 7/8 BSF or 3/4 Whit (worth). If your pocket is deep enough, perhaps get a socket with a 3/4" drive and "T" bar to go with it as you do really have to lean on these to get the right torque. Having said that, I use a 1/2" bar with a lump of gas pipe to extend it. You will also need to make / get a bar which will block the hub from turning whilst you do the nut up. Various patterns exist. Now ignore everything I have said and read this instead !!! http://www.ba7c.org/technicalArticles/hubsRear.html BobH RE: Size of socket for half shaft nuts? - Stuart Giles - 01-11-2018 the later halfshaft nuts your car will have are 3/4" Whitworth 11/16" BSF. But as BSF/Whit sockets aren't easy to find nowadays, a 33mm socket will also be a pretty well perfect fit. RE: Size of socket for half shaft nuts? - Joe eck - 01-11-2018 Thanks Bob / Stuart. I have made a hub securing jig , so I will now go on the hunt for a suitable socket and set about some strong arm work. Many thanks for the info. Joe. RE: Size of socket for half shaft nuts? - Martin Prior - 01-11-2018 (01-11-2018, 04:20 PM)bob46320 Wrote: Mine is marked 7/8 BSF or 3/4 Whit (worth). If your pocket is deep enough, perhaps get a socket with a 3/4" drive and "T" bar to go with it as you do really have to lean on these to get the right torque. Having said that, I use a 1/2" bar with a lump of gas pipe to extend it. You will also need to make / get a bar which will block the hub from turning whilst you do the nut up. Various patterns exist. Now ignore everything I have said and read this instead !!! I would go with Ian Moorcroft's advice on the BA7C site. An excess of brute force isn't necessary. I've only ever used a standard ring spanner on hub nuts - no extension bar - although I will admit to usually giving it one sharp tap with a 4lb hammer to finish. Both the RP and the PD have covered at least 40k since the hubs were last re-assembled with no need to re-tighten the nuts. RE: Size of socket for half shaft nuts? - Colin Wilks - 01-11-2018 How tight is tight? I recall reading somewhere that 150 lbs/ft is a good guide and this is the figure I'm planning on using when I do my hubs for the first time. Does anyone with experience AND a torque wrench have a value in mind? Having posed this question I have to say I think it's much more important to ensure the hub and taper are well matched by lapping and that the Woodruff key is a good fit (i.e. not at all loose, but not binding either). RE: Size of socket for half shaft nuts? - Bob Culver - 01-11-2018 Over the decades the nuts on my car were tightend with a 12 inch Crescent without any hammering etc. The original axles were in place at 110,000 and no problems with successors, except very difficult to pull apart! RE: Size of socket for half shaft nuts? - Tom the Blacksmith - 01-11-2018 Hi Joe, I found 3/4 Whit and 7/8 Bsf sockets hard to find but 1 5/16 AF a close fit and much easier to come across, I found a 1/2" drive one in an army surplus for £4. Tom RE: Size of socket for half shaft nuts? - Stuart Giles - 01-11-2018 I use a 30" breaker bar to tighten the halfshaft nuts. On one occasion, just out of curiosity, I put my 3/4" drive torque wrench on an already tightened nut. I had the dial up to 100 lb ft without any movement; just as well as I had lined up the split pin hole already ![]() As said, the prime thing is a good fit between the shaft and hub, it's worth spending a bit of time lapping the hub to the shaft if engineers blue or chrome yellow doesn't show a decent contact area. I also use an equivalent goop to Loctite 641 on the shaft to hub joint, and they've always come apart OK with the correct persuasion. RE: Size of socket for half shaft nuts? - Hedd_Jones - 02-11-2018 You'll probably pick up a suitable whit ring spanner up at a steam rally for less than a fiver. It will be approx 15 inches long which gives ample leverage IMO. Particularly if you use your feet. |
