Body inside padding - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Body inside padding (/showthread.php?tid=184) |
Body inside padding - "Slack Alice" Simon - 03-09-2017 Hello, all My '34 Tourer has traces of padding, like sound deadening material, between the vertical ribs on the inside of the rear body panel, visible when the seat back is removed. Was there anything there originally, and if so, how was it fixed on? The sidescreens are supposed to be stored here, so some padding is likely, I think. But it wouldn't have been stuck on using upholsterer's spray contact adhesive, that's for sure!. Thanks Simon |
