1930 Austin 7 Headlamp Reflector,Glass & Outer Rims - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: 1930 Austin 7 Headlamp Reflector,Glass & Outer Rims (/showthread.php?tid=1799) |
1930 Austin 7 Headlamp Reflector,Glass & Outer Rims - Yugath - 27-09-2018 Hello Guys I have a 1930 Austin 7 I need a pair of Reflectors,Head lamp Glasses & Outer Rims If any one know where to buy these parts please let me know Thanks RE: 1930 Austin 7 Headlamp Reflector,Glass & Outer Rims - Reckless Rat - 27-09-2018 Stuart Joseph. See oldcarservices.co.uk RE: 1930 Austin 7 Headlamp Reflector,Glass & Outer Rims - Rick F - 27-09-2018 The first thing to ascertain is the type of lamp fitted - after nearly 90 years there's no guarantee that the lamps are the original type, or even off an Austin 7! Reflectors and glasses for standard sizes are fairly readily available from the usual "cherished suppliers" - rims are often more of a problem. RE: 1930 Austin 7 Headlamp Reflector,Glass & Outer Rims - Stuart Joseph - 30-09-2018 Good evening. Apologies for the delay in replying to your post but I have just returned from holiday. If you would like to give me a call tomorrow on 01785 850916 we can discuss your options. Regards from the creative county, Staffordshire Stuart RE: 1930 Austin 7 Headlamp Reflector,Glass & Outer Rims - Zetomagneto - 30-09-2018 (27-09-2018, 03:52 AM)Yugath Wrote: Hello GuysIf you have R47 lamps you can get proper reflectors and rims from Reproduction Austin Parts,they are very good copies of originals and fit properly on the original locations Glass’s can be cut by Roman glass, or other good glass merchant. I have just fitted a pair. |
