radiator - Printable Version
+--- Thread: radiator (/showthread.php?tid=1719)
radiator - rubyman - 13-09-2018
Having had to drain my Ruby radiator a few times, I wasn't  happy to see the water running all over the wiring loom, so I removed  the rad and drilled the tap 5/16 put a inch long piece of 5/16 brake pipe covered with J B Weld into the tap with 1/2 showing, fastened a piece of rubber hose to the showing pipe and now the water drains into a container with out running all over the steering & wiring  Big Grin
