Spring packing - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Spring packing (/showthread.php?tid=1657) |
Spring packing - Scarlet O'Hara - 02-09-2018 I be interested to know what material has been used for front spring packing in the past and what length and thickness to make it. What was originally used in the factory? RE: Spring packing - Ian Dunford - 02-09-2018 As far as I have been able to ascertain over the years front spring packing seems to serve no purpose at all other than to give you a tiny increase in ground clearance. RE: Spring packing - Dave Wortley - 02-09-2018 The bit of packing I have (somewhere) is about 3/16” red fibre. It came off my RN saloon. The road springs no longer have packing. Cheers, Dave. RE: Spring packing - Chris KC - 02-09-2018 Scarlet, You may find Ian's wisdom a comfort when you discover nobody stocks it anyway. (Actually if you do find some please let me know 'cos I need a bit of vulcanised red fibre board for something else). I did in the past substitute copper or brass sheet without detriment. btw the old packing I have was more like 1/16" than 3/16", though heaven knows what's 'correct'. RE: Spring packing - Ian Dunford - 02-09-2018 If you really want to The Seven Workshop used to stock red fibre spring packing. RE: Spring packing - Hedd Jones - 02-09-2018 Ive never distmantled a car with any. A piece of asbestos jointing would do a similar job to the fibre sheet RE: Spring packing - Andy Bennett - 02-09-2018 I used the red packing for my rear springs (from Seven workshop) to ensure a tight fit in the chassis members. I didn't include any on the front, partly because there was none in there on the spring I removed and also because I was concerned that it reduced the purchase of the centre spring locating pin. Andy B RE: Spring packing - jansens - 02-09-2018 I think I got one from our local (NZ) spares a while back but then didn't use it on the spring, instead I cut it into strips and made a fuel stick for the Chummy I had for a while! Simon RE: Spring packing - Chris KC - 02-09-2018 (02-09-2018, 09:19 PM)jansens Wrote: I think I got one from our local (NZ) spares a while back but then didn't use it on the spring, instead I cut it into strips and made a fuel stick for the Chummy I had for a while! That's what I wanted it for! RE: Spring packing - Tony Press - 03-09-2018 (02-09-2018, 08:08 PM)Ian Dunford Wrote: If you really want to The Seven Workshop used to stock red fibre spring packing. Welcome back Ian- if I remember you had some difficulties in 'logging on' Tony. |
