Eyes and Tees - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Eyes and Tees (/showthread.php?tid=1566) |
Eyes and Tees - Steve kay - 10-08-2018 Nothing to do with punctuation. Do any of our revered suppliers keep lifting eyes or Ts to thread into spark plug spaces for raising of engines or just cylinder heads? If none are to be found, when I ask one of the local small engineering shops I'll see what a small batch might cost, unless an immediate reply tells me another way to do it. RE: Eyes and Tees - peter burton - 10-08-2018 Buy some expensive gadget to lift heads/engines, the wallet has just locked up solid. Just find a dead 14 or 18mm plug and remove the ceramic centre, I crunch the ceramic in a vice covered in an old cloth to avoid splinters. Knock out any remains so the plug is now hollow and push a coach bolt or similar through the threaded end of the plug, bend the top into a hook or T, job jobbed. The plug end being free to rotate is so useful too when extracting and fitting engines.. Plug hole 3 with gearbox, 2 just engine. Peter. RE: Eyes and Tees - Reckless Rat - 10-08-2018 Similar gadget but I used the S hook from a motor cycle tie down welded onto an old spark plug. RE: Eyes and Tees - Austin Carr - 10-08-2018 From http://www.austin7.org/Quick%20Tips/ RE: Eyes and Tees - Phil Kingdom - 10-08-2018 See my post in the thread, Necessity is the mother of invention. 29-7-18 if you do not have access to welding equipment. |
