engine cylinder block 1933-ish - Printable Version
+-- Forum: Sales & Wants (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=9)
+--- Forum: Sales (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=10)
+--- Thread: engine cylinder block 1933-ish (/showthread.php?tid=152)
engine cylinder block 1933-ish - JonE - 26-08-2017
good sleeved standard block, i.e. back at 'datum' measurement 2.19". Probably wants a light hone (is that the right word?) before use.
I can take photos of anything you want inspected.
£80
Another thing kicking around that realistically I'm never going to make into an engine so might as well help someone else do so.
RE: engine cylinder block 1933-ish - Reckless Rat - 31-08-2017
(26-08-2017, 02:44 PM)JonE Wrote: good sleeved standard block, i.e. back at 'datum' measurement 2.19". Probably wants a light hone (is that the right word?) before use.
£80
Where are you exactly?
RE: engine cylinder block 1933-ish - A7novice - 25-09-2017
Hi JonE,
is block still available or have you sold it?
regards
(If not, where in country are you?)
RE: engine cylinder block 1933-ish - JonE - 25-09-2017
Sorry, its now packed up for dispatch.
No worries, cheers
