Front spring thickness - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Front spring thickness (/showthread.php?tid=1379) |
Front spring thickness - Erich - 24-06-2018 I just recently purchased a new front spring shackle(U bolt) from one of the cherished suppliers. I have an Ulster Rep with a dropped front axle and a flat spring with seven leaves. When the shackle arrived, it was 1/4 longer than the existing ones, and the threads were 1/4 inch short. Fortunately I had a die and was able to add threads and then shorten the over all length of the shackle. I'm curious, are Ulster (rep) springs usually thinner than on standard cars? Erich in Seattle |
