Broken Horn Switch - Replacement? - Printable Version
+--- Thread: Broken Horn Switch - Replacement? (/showthread.php?tid=1340)
Broken Horn Switch - Replacement? - Matt_Harnden - 17-06-2018
My horn switch has stopped working as it is quite badly corroded. I have good power connectivity either side of the switch so I know this is my problem. Does anyone have a replacement please or knows of an alternative switch that will do the job? My switch is from a Ruby/Opal/Pearl.
Thanks for your help.
Matt
RE: Broken Horn Switch - Replacement? - John Mason - 17-06-2018
Hi Matt, Looking at the photo although rusted and corroded is looks reasonably sound. Is it possible to clean up the electrical connections to make it work again.
John Mason
RE: Broken Horn Switch - Replacement? - Ian Williams - 17-06-2018
If can not find one locally and you are willing to pay the postage PM me I can send you the parts you need.
RE: Broken Horn Switch - Replacement? - Derek Sheldon - 17-06-2018
Matt, hold on , I think that I have pne
RE: Broken Horn Switch - Replacement? - Nick Lettington - 17-06-2018
If you don't already have one, I have this one which I have no plans for... It may clean up ok.
