Slippery Anne Engine - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Slippery Anne Engine (/showthread.php?tid=1332) Pages:
1
2
Slippery Anne Engine - Mark Atkinson - 14-06-2018 In a recent thread I promised to post some pictures of the engine once in the car, my son Peter helped me to drop the unit into the car today, which naturally led to some photography. The engine has now run up to 8200 rpm and 7 pounds of boost, which must be a shock for the 1924 crankcase. It is good to have a willing pair of hands to help out, I do feel lucky to have a 16 year old son who takes such a proactive interest. Regards, Mark. RE: Slippery Anne Engine - jansens - 14-06-2018 Hi Mark, excellent pictures, thank you! How did you make the pop off valve on the end of the inlet manifold? Simon RE: Slippery Anne Engine - Ruairidh Dunford - 15-06-2018 8200 rpm - holy s**t!!! You do things very well Mark! RE: Slippery Anne Engine - Tony Press - 15-06-2018 (15-06-2018, 12:02 AM)Ruairidh Dunford Wrote: 8200 rpm - holy s**t!!! Amazing ! But much too clean for an Austin Seven RE: Slippery Anne Engine - Erich - 15-06-2018 Impressive work, Mark! Thank you for posting. Erich in Seattle RE: Slippery Anne Engine - John L - 15-06-2018 Fantastic project and a beautiful looking engine! Willing to share it's spec? John RE: Slippery Anne Engine - AllAlloyCup - 15-06-2018 Hi Mark Sounds as if it could be a lot, lot faster than the original? Is this car for circuit racing Or Sprints? Or Roadgoing!!!? Bill G RE: Slippery Anne Engine - Ian Williams - 15-06-2018 Bill, you are probably correct but remember it is extremely unlikely that the engine will achieve those rev's when in the car and under load. if it did we would be looking at something over 120mph. Mark will correct me if I am wrong, but as I recall the factory struggled to get enough power to push the car much over 95mph, however Mark may well achieve the magic Ton which eluded the factory for so long. RE: Slippery Anne Engine - Bob Culver - 15-06-2018 That handiwork too good to damage. 5 squared is 25, 8.2 squared is 67! A 170% increase. What rpm was the original held to? The owners of the NZ Rubber Duck never managed to put the original crankcase back together again successfully. RE: Slippery Anne Engine - jansens - 15-06-2018 Have you made any mods to ensure the block stays attached to the crankcase? |
