steering light... wandering - Printable Version
+--- Thread: steering light... wandering (/showthread.php?tid=1324)
steering light... wandering - dockerpt - 12-06-2018
Good day
I have my chummy back from menders and now to getting on with mending!  The steering still seems light and id say twitchy.... its a 27 chummy...
I had a special a long time ago and I don't remember it like this.....
Also it NEVER goes on the handle...... I'm guessing  the pin the butterly is on is worn and its sucking in air weakening the mix when trying to start...
Finally steering arms..... how many here have replaced as a matter of course.....
replies
Best
Pete
RE: steering light... wandering - bob46320 - 12-06-2018
Steering arm replaced. Twitchy steering, check your "toe in / out". My steering went from heavy to twitchy and then normal by slight adjustment of the track rod.
RE: steering light... wandering - Tony Press - 12-06-2018
(12-06-2018, 07:15 PM)dockerpt Wrote: Good day
replies
Best
Pete
 Check kingpin caster - a slight backward lean makes a great difference.
Still on the original steering arms.
Cheers, Tony.
RE: steering light... wandering - Nick Turley - 13-06-2018
Checking the tracking would help you i am sure.
RE: steering light... wandering - dockerpt - 13-06-2018
what is the typical toe in recommended...?
