Flickering oil pressure gauge - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Flickering oil pressure gauge (/showthread.php?tid=1305) |
Flickering oil pressure gauge - Nick Lettington - 08-06-2018 Can anyone tell me why my '35 ORT oil guage gets a fit of the shivers from time to time? At first I thought it might be oil level (though it was still at half mast)... then that it might be running hot... it doesn't happen all the time which is more confusing... Is it normal or should I be expecting a bit of work on my engine soon... Slightly worried of Colchester. RE: Flickering oil pressure gauge - Dave Wortley - 08-06-2018 Nick, There may be an air bubble between engine take off and gauge. RE: Flickering oil pressure gauge - Nick Lettington - 08-06-2018 That's reassuring... But I don't understand why it would flicker... I wouldn't have expected the tube to be fully filled with oil... Its not as if you bleed it when you refit an engine..? RE: Flickering oil pressure gauge - Robert Leigh - 08-06-2018 (08-06-2018, 04:43 PM)Dave Wortley Wrote: Nick, There may be an air bubble between engine take off and gauge.A lot of Rileys have air bells in the oil line to eliminate gauge fluctuations; normally an air bubble is unavoidable and serves as a useful damper. Robert Leigh RE: Flickering oil pressure gauge - John Mason - 08-06-2018 Nick. Could it possibly be a little dirt or similar in the pipe or gauge which is moving around causing an intermittent partial blockage. Also check the pipe union which fastens to the head for dirt. John Mason RE: Flickering oil pressure gauge - Speedex750 - 10-06-2018 Hi Nick, I would suggest giving the oil jets a prod through and reseat the pressure relief valve. It's just about do-able insitu if you jack the engine up. Give the cleaned up ball a tap with a hammer and drift to reseat it in the crankcase. Dave |
