Roof edge sealant - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Roof edge sealant (/showthread.php?tid=1075) |
Roof edge sealant - Pearls not a Singer - 13-04-2018 I'm just about to re-roof my RP saloon, so need to find a suitable seal for the edge of the roof where it sits in the metal body. There's a bewildering array of acrylic, silicone and other products. This is a difficult area as the product needs a long life withstanding high temperatures, UV, differential movement, vibration,and water! Any recommendations for the best product(s) gratefully received RE: Roof edge sealant - cardiffrob - 14-04-2018 Might be worth a call to Sika to see if they have a technical department? https://www.sika.com/en/solutions_products/industry-markets/automotive-aftermarket/sealing-bonding.html RE: Roof edge sealant - Ruairidh Dunford - 14-04-2018 I have always used this David: https://www.thecampercoshop.com/index.php/catalog/product/view/id/53/s/sikaflex-221-black-multi-purpose-adhesive-sealant/?loc=gb&gclid=EAIaIQobChMImNyKrpS52gIViCnTCh3k-AM5EAQYASABEgIw0fD_BwE RE: Roof edge sealant - Hedd Jones - 14-04-2018 I rank Sika technical as i was after some sealant for a wood bead on my living van. The stuff they recommended has stopped the paint that I've overpainted it with going off. Ahould have used Tiger Seal. Never had any problems with that. RE: Roof edge sealant - Colin Morgan - 14-04-2018 When I did mine 18 years ago, I used a black closed cell neoprene stip, about an inch wide and 1/8" thick - thinking that it would be easy to dismantle again. However, this has never been necessary. It has never leaked. Regards Colin RE: Roof edge sealant - Dave Mann - 14-04-2018 I've tried a variety of modern sealants on our 3 RN saloon fixed rear roofs, all of which worked for a couple of years and then started to leak. I finally used what Austin's used black bitumen sealant with total success over 15 years, I jut hope I don't have to remove them. RE: Roof edge sealant - Peter Naulls - 14-04-2018 My neighbour carries out camper van conversions. He uses Sika 221 to attach the pop-up roofs. Its very tough indeed - I helped him cheese-wire off a damaged roof one day and thought we were never going to get through it! I can't vouch for it's longevity though as he doesn't keep them long. Peter. RE: Roof edge sealant - bob46320 - 15-04-2018 Go to your local boat shop and ask for deck sealant - its made for rough weather hot and cold. RE: Roof edge sealant - Andy Bennett - 15-04-2018 I used black house gutter mastic from. B&Q to fill in cracks in the old sealant on my RP about 8 years ago and it is still flexible, crack free and firmly attached. Andy B RE: Roof edge sealant - Pearls not a Singer - 18-04-2018 Thanks for all replies - looks like sikaflex or tiger seal |
