Easier/quicker gear changes - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Easier/quicker gear changes (/showthread.php?tid=1028) |
Easier/quicker gear changes - wooster - 01-04-2018 When I approach a corner at speed in my Ulster rep I want to change down from 4th to 3rd to take the corner quickly. However it won't go into 3rd. I'm guessing it won't go in because the revs are still high. Anything I can do about that? I do like to drive the car hard!! Cheers Rich RE: Easier/quicker gear changes - bob46320 - 01-04-2018 (01-04-2018, 09:44 AM)wooster Wrote: When I approach a corner at speed in my Ulster rep I want to change down from 4th to 3rd to take the corner quickly. However it won't go into 3rd. I'm guessing it won't go in because the revs are still high. Anything I can do about that? I do like to drive the car hard!! Get a 3 speed box ?? RE: Easier/quicker gear changes - Colin Wilks - 01-04-2018 Rich, you sound as bad as my French girlfriend Avril, who could never get it into first. I used to tease her about it. RE: Easier/quicker gear changes - wooster - 01-04-2018 I can get it into 3rd but only by slowing down more. And I don't want to slow down! RE: Easier/quicker gear changes - Phil Kingdom - 01-04-2018 Have you tried double de-clutching? It will match the engine speed to the gearbox and you should be able to engage 3rd gear without difficulty. RE: Easier/quicker gear changes - wooster - 01-04-2018 Yes I am double de-clutching. Guess I need more practice. Thinking of fitting a short-shifting kit too. RE: Easier/quicker gear changes - stuartu - 01-04-2018 "Guess I need more practice." Or a closer ratio box, maybe super accessories ratios? Regards, Stuart RE: Easier/quicker gear changes - AustinWood - 01-04-2018 Perhaps rev harder in neutral on the downshift. RE: Easier/quicker gear changes - Duncan Grimmond - 01-04-2018 A short shifting kit will not affect the revs but a heavy boot will! It took me ages to suss that the difference between engine and transmission speed was so great that a hefty footful of throttle was required for a smooth double de-clutch. RE: Easier/quicker gear changes - Alan - 01-04-2018 Well, a standard gearbox isn’t a lot of help for quick gear changes. I’d use a set of Nippy ratios for road use - you can buy new ones. However, if you have a standard flywheel, you really need to lose some weight from it. Quite a lot, in fact. A search of the old forum should reveal how. |
