Genuine Ulster(Ulster Rep) bonnet rubber - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Genuine Ulster(Ulster Rep) bonnet rubber (/showthread.php?tid=4600) |
RE: Genuine Ulster(Ulster Rep) bonnet rubber - Mike Costigan - 30-08-2020 That looks like the section I recall fitted to both my Ulster and Type 65. RE: Genuine Ulster(Ulster Rep) bonnet rubber - JonE - 30-08-2020 Mike, so designed to go under the bonnet... but not protecting against scuttle scrapes? And giving a smooth line from bonnet to scuttle without a bump? That bonnet in the pic seems a bad fit. RE: Genuine Ulster(Ulster Rep) bonnet rubber - Mike Costigan - 30-08-2020 (30-08-2020, 09:05 AM)JonE Wrote: ... And giving a smooth line from bonnet to scuttle without a bump? Yes, my memory suggests the high point of the rubber was near-enough flush with the outer surface of the bonnet/scuttle, perhaps just a millimetre or two above the panel line. RE: Genuine Ulster(Ulster Rep) bonnet rubber - Ian Williams - 30-08-2020 Like a Ruby Rubber Mike? |
