60’000 miles on cheap supermarket oil... - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: 60’000 miles on cheap supermarket oil... (/showthread.php?tid=4251) |
RE: 60’000 miles on cheap supermarket oil... - AustinWood - 29-04-2020 I think the Phoenix oil troughs are an improvement over the original. The way they are machined will hold the oil rather than it being flung out by centrifugal force. The troughs are closer to the centre line and the drilling to the big end goes straight through at an angle rather than having 90 degree bends. It is essential to angle the jets correctly. RE: 60’000 miles on cheap supermarket oil... - Ruairidh Dunford - 29-04-2020 Rebirth has begun... RE: 60’000 miles on cheap supermarket oil... - John3528 - 29-04-2020 Thanks Ruairidh. Your point about Phoenix cranks well noted. RE: 60’000 miles on cheap supermarket oil... - Ruairidh Dunford - 29-04-2020 If I remember, I will try to take some photos once the cranks is in, to show the difference - side to side. |
