Warning [2] Undefined property: MyLanguage::$archive_pages - Line: 2 - File: printthread.php(287) : eval()'d code PHP 8.1.29 (Linux)
A New Austin Seven Owner - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: A New Austin Seven Owner (/showthread.php?tid=9564) |
RE: A New Austin Seven Owner - John Cornforth - 06-09-2024 To underline what Reckless says, the cotter pins are of the "half moon cutout" type, not taper pins like a bicycle crank. The same sort of cotter is used on the fan spindle tension adjuster. Many folks have hammered away at these in the past in a doomed attempt to remove them with the kingpin still in place, at best they have got nowhere, at worst they have broken something ! RE: A New Austin Seven Owner - Turboseven412 - 07-09-2024 Im glad to have been told this because I certainly would have tried removing the cotter otherwise! RE: A New Austin Seven Owner - Chris Garner - 07-09-2024 SRVBTGNYUMI,KOL.P;['][-POI8U7Y6T5R4321` RE: A New Austin Seven Owner - Robert Leigh - 07-09-2024 Excuse my ignorance Chris, but what does your character string mean? Google does not recognise it. RE: A New Austin Seven Owner - Hugh Barnes - 07-09-2024 I think his cat just walked across the keyboard... RE: A New Austin Seven Owner - Ivor Hawkins - 07-09-2024 I think Chris has been on the gin! RE: A New Austin Seven Owner - andrew34ruby - 07-09-2024 Regarding the Bowdenex replacement front brake cables.... I drove for about 4 years with the Bowdenex cables, then when fitting a new spring and a different axle following accident damage I was recommended to revert to standard cables. I've been driving on the original type cables for a few weeks now. I can't tell any difference. RE: A New Austin Seven Owner - Nick Salmon - 07-09-2024 Chris' post is code for the secret to complete and eternal Austin SevenĀ knowledge. None of us will ever decipher it... RE: A New Austin Seven Owner - Reckless Rat - 07-09-2024 The meaning of all A7 knowledge and of life, is 42 RE: A New Austin Seven Owner - Turboseven412 - 07-09-2024 Chris I've been thinking the same thing for years, I'm glad someone has finally came out and said it |
